My feeds all have numbers showing that there are stories to be accessed, but they also all open showing nothing at all. I can access the stories by using the original setting, but then stories I have read do not go away, they just keep opening again the next time.
You probably are in some mode (Text or something) and have disabled story titles. Can you post a screenshot? Can you play around with the view options at the bottom of the screen?
