Feeds from ebdz.xyz not working
Hello,
Feeds provided by a forum built with MyBB do not seem to be retrieved correctly or parsed correctly.
example of URL <![CDATA[EmuleBDZ]]>
To be honest Feedly or Innoreader are not doing better, but the RSS reader of Vivaldi do retrieve it OK, below the beginning of the code retrieved (I can provide the full version as needed).
Should Newsblur be able to get it right, I would really consider a paid subscription…
Thanks a bunch
<?xml version="1.0" encoding="UTF-8"?> https://ebdz.xyz/forum/ 2023-03-11T09:41:46Z MyBB <![CDATA[DST]]> 2023-03-11T09:22:04Z 2023-03-11T09:22:04Z https://ebdz.xyz/forum/showthread.php?tid=29518 <![CDATA[
LES FONDUS DE MOTO
I don’t know for sure but it looks like the feed itself is empty:
https://validator.w3.org/feed/check.cgi?url=https%3A%2F%2Febdz.xyz%2Fforum%2Fsyndication.php%3Ftype%3Datom1.0%26fid%3D23
Thanks for the reply and for investigating.
I understand. As the feed works in Vivaldi browser that includes a RSS/Atom client maybe it’s done by Vivaldi in a non standard way, I would not know. I shall remain with that solution then.
Cheers
