The control does not function for the “All Site Stories” folder. The Newest/Oldest, Read/Unread dialog does not appear when I click it; there is nothing in the javascript console.
It does work for “normal” folders.
It did not work for a while then did work recently (maybe a week or two ago?) then stopped working again in the last week.
That should be: “The control < div id=“NB-feedbar-options” > […]”
I’ve had this problem intermittently too — couldn’t ever get it to reproduce enough to report, but since someone else is having the problem…
Reloading the page always fixes the problem for me. What browser/version/OS are you using?
Chrome-29 on Linux. Reloading did seem to help, just now; thanks.
I figured out a reproduction recipe that works on both Safari and Firefox:
- Go to https://www.newsblur.com/folder/every…
- Click on another folder
- Click back on “All Site Stories”
- Click on the options control
Nothing should happen (at least, it doesn’t, for me).
This has been fixed. Was a bit more complicated than I thought, but I ended up optimizing the structure of that story titles header and it now won’t have to fully redraw after every feed/folder load (and re-attach its event handlers, which was responsible for closing the popover as soon as it was opened).
It works, and switching folders does seem more responsive now - thanks.
