I am using Firefox 23 with Firebug. Using Firebug, I can turn off the max-width attribute, and when I do the image displays at full size. When on the image is at 90-95%. These images are not larger than the window, there is no need to resize them.
This is for the Feed View. If I switch to Story View the image is full-size.
I am experiencing this with multiple different webcomics. For example, xkcd.com
I believe if you simply remove the max-width from your CSS, it will fix the problem.
I have just double-checked them on Firefox and Chrome.
The latest xkcd comic is not resized, because it is a smaller single-panel comic, however if you look at the comic from Jan 26th - http://xkcd.com/1322/
It is resized for me.
Diesel sweeties is generally a wider format, and the resizing is more obvious.
I am viewing on a 1920x1200 screen. Newsblur appears to expect a maximum window width of about half that. All articles, text and pictures will not expand to fill the full window. Forcing a max-width is frustrating. If I want a smaller window I can resize it.
