The following feed has stopped updating
http://www.steynonline.com/rss.xml
and reports a last checked date of 510 days ago. Also, it won’t show older stories that I did read (just a blank white pane). I checked that the address of the feed is still accurate so I’m not sure what is going on here.
You can right-click on it and force it to insta-fetch stories. That will also kickstart it to start fetching again.
Also, I added some logic to force old feeds to get periodically re-checked. Not sure why it isn’t firing on this feed.
I’ve tried the Insta-fetch and nothing happens. The little arrows spin for a bit, then stop as if it is done, but still no stories appear.
Ah-ha, fixed it. It was a bug in how feeds were merged.
