VlaKor
May 26, 2022, 1:53pm
#1
Hello!
Help please
Lost access to the site from the PC, error ERR_CONNECTION_TIMED_OUT
sending ICMP ECHO request to www.newsblur.com …
PING www.newsblur.com (159.223.189.24) 56 (84) bytes of data.
84 bytes from www.newsblur.com (159.223.189.24): icmp_req=1, ttl=55, time=142.36 ms.
84 bytes from www.newsblur.com (159.223.189.24): icmp_req=2, ttl=55, time=142.28 ms.
84 bytes from www.newsblur.com (159.223.189.24): icmp_req=3, ttl=55, time=141.46 ms.
84 bytes from www.newsblur.com (159.223.189.24): icmp_req=4, ttl=55, time=141.79 ms.
84 bytes from www.newsblur.com (159.223.189.24): icmp_req=5, ttl=55, time=150.43 ms.
— www.newsblur.com ping statistics —
5 packets transmitted, 5 packets received, 0% packet loss,
0 duplicate(s), time 4152.86 ms.
Round-trip min/avg/max = 141.46/143.66/150.43 ms.
VlaKor
May 26, 2022, 1:57pm
#2
If I connect via vpn then everything works
VlaKor
May 26, 2022, 2:17pm
#3
Any device on the home network cannot connect to the site
VlaKor
May 26, 2022, 2:48pm
#4
Friends tell me where to dig
VlaKor
#5
It feels like I’ve been banned by IP
VlaKor
May 27, 2022, 6:53am
#7
After restarting the PC and router, the site loads once and works for a couple of seconds and then there is no response.
Hi, it is entirely possible your IP was banned. Are you running anything out of the ordinary?
VlaKor
June 10, 2022, 6:27am
#9
Blocked by whom?
Everything works on a mobile phone through another provider. So the home provider is blocking your address?
I am not an expert in these matters.
NewsBlur very well may be blocking your access due to bot like behavior. What’s your IP? And are you doing anything exotic that may have triggered the ban?
VlaKor
June 10, 2022, 3:43pm
#11
IP I won’t be able to watch it until next week.
I work on the watch.
VlaKor
#12
I didn’t do anything exotic
VlaKor
June 14, 2022, 1:25pm
#14
Hello
Dynamic IP address 178.64.78.49
VlaKor
June 14, 2022, 1:28pm
#15
Or maybe my provider is blocking access to your site?
VlaKor
June 14, 2022, 3:18pm
#16
We checked with a friend on his PC with the same provider, everything works. Everything is very strange.
VlaKor
June 16, 2022, 12:30pm
#17
Everything is fine, it works! Thanks!
