Constant android error
#1
Developer warning for package “com.newsblur”
Failed to post notification on channel “null”
See log for more details
^^ I get this over and over whenever I do anything. It only started today. Not sure how to view the log. I’m using the beta package 9.0b1 on Android 9 Pie.
#2
Thanks for the report. The beta channel is actively testing some brand-new compatibility cases for Android 9. If you get any issues, please do use the “Send app feedback -> Email a bug report” menu option after you get an error, if possible. If the errors are repeated enough to negatively impact your reading, certainly don’t feel obligated to stay on the Beta!
