Just took a stab at building from your github readme (master: 558ca3f34a10675829dd9a980a3d049e074593a1).
Seemed to go smoothly, no errors and it’s up and running with a bunch of containers. But when I visit the initial landing page https://localhost I run into a couple errors.
The main error seems (a semi-educated guess?) that it’s not importing underscore. The error is that “_.memoize” is not a function (error in reader_utils.js), and if I poke around in the source or devtools I only see underscore.string.js being pulled in (which doesn’t have memoize).
I’m also getting a 403 on https://cloud.typography.com/6565292/711824/css/fonts.css, but that seems like it would be a secondary concern.
I do have a bit of a strange environment going on and a few things that are new to me (wsl2+docker) so it’s probably something on my end, but was hoping maybe it was something obvious you might be able to point me in the right direction? There sure is a lot going on and so much of it went without a hitch, so hoping for the best.
Thanks
