Bug scrolling with spacebar
Hi
On the web, since today, scrolling with the spacebar doesn’t work as it should, it “stutter”.
Can be just once or a lot before scrolling effetively.
Yes I definitely changed something about this yesterday in hopes of trying to get story selections more accurate, since image loading was pushing stories down after trying to select a story. I’ll take a look and see if I can figure it out.
Ok, reload NewsBlur on the web, this should now be fixed.
Yes it’s fixed, thanks
