Integrate ability to change Background from white to light blue or light green, to minimize eye strain, should be under Preferences, if deemed worthy of inclusion - I spend about four hours a day on here. Thank you …
Download the Stylish browser extension and install the CSS stylesheet from userstyles.org called “NewsBlur - Dark Theme”.
I’ve been trying for ages to get an official dark theme added. But until then, I will suggest the same as Tazio said.
I suggest getting this theme: https://userstyles.org/styles/124890/newsblur-dark-theme-by-splike
As it is maintained by me and the most up to date dark theme there is.
Well, I did, and it really helps. Thank you Tazio and Splike
This is awesome!
