Thanks for trying to help.
If I am actually reading a story, I tap into it. Otherwise I long press and tap on “Mark Older as read”. In the Android app, the actually read story stays put, the marked as read ones disppear.
I must say I preferred it when the marked as read stories stayed, but just greyed out. That still happens in the Windows web browser. It is far better when you realise that the next story you were just about to read was actually the same time as the one you’ve long pressed on, because they both disappeared.
In general, that means I mark up to the last story on a page each time, so that the first unread story jumps to the top of the page. Otherwise I have to scroll to get to the first unread. In any event, I have to scroll to get the actually read articles right up to the top of the page to be able to see more unread ones.
If I have the newsblur.com tab open, and on my Android “Mark older as read”, the left column with the feed names flashes on the feeds that have been bulk marked as read, and the unread count against each feed name updates accordingly. Nothing happens in the tab if on the Android I actually read a single story, or If I long press a story and tap “Mark as read”. No action on my tablet updates the right window of the story list in the web tab.
When the app appears to update, the stories go away only to return a few seconds later (it hasn’t happened tonight, but happened once this morning i.e. Friday) I generally get the most recent batch of “Mark older as read” items back. Actually read items stay as actually read, and end up within the others that are bold. Usually they reappear after a few seconds - occasionally when I return from reading a story that grabbed my eye. I’ve not known it happen more than a few seconds after marking, unless within that time I have actually read a story.
NB I have not been near my PC to investigate this when the stories return.
If I again “Mark older…” they usually go away permanently. However, on occasion when I’ve got fed up with the most recent stories reappearing, I have done the mark older… and then immediately returned to the summary screen; that has never left any marked as read showing as unread.
I had three new stories and tapped on the tick near the top right . I OKed the dialogue to mark the entire feed as read. That has NOT updated the unread counts in the web tab on my PC. My tablet still shows no stories to read. Refreshing the web tab has cleared all the stories.
I hope this all makes some sort of sense.
Jim
