Android: material design
You guys really need to update to material design.
I personally love the Android app as is.  material design is all fluffy and pretty, and wastes an awful lot of space.
Would also love to seen an update to Material Design, if for no other reason than easier browsing/collapsing of folders, which is a little weird right now.
It may be just because it’s the workflow I’m more used to in other apps, but having the drawer on the side lets me swap between things more quickly, and usually the buttons/text is fairly large? Or at least enough so that I can use my thumb to jog through them. Right now it seems like I have to tap ‘back’ a lot and aim pretty tightly to make things happen.
Certainly not awful, and I don’t want to sound overly critical, as it’s a totally useable app. It’s just nice to have the same basic patterns in all the programs I’m using as opposed to individual ones. That said, if it keeps allowing me to get through my articles, I’ve got no major complaints.
Did not know about the swipe! I will be using and abusing that from now on. Thanks for the tip! ^^
