On android there’s 2 problems since the last update, one with saving stories and tags: it seems not possible anymore to attribute an existing tags to a story saved, it’s only possible on the web (and need to be unsaved first, then re-saved otherwise it goes on “highlight”)
The other problem is with display: when swapping stories if I’m swapping forward, then one story back and then forward, the first story forward is ok, the second one is empty but stories after are ok.
If I’m swapping forward, then one story back and then continue to swap back, all stories after the first one are empty.
Don’t know if the 2 problems are link but they appeared at the same time for me.
@Guybrush I found the issue for the story content loading.
On adding tags - I do see the Add Tag button on saved stories and I can add new tags. Am I looking in the wrong place?
Sadly the problem re-appear with the 13.10.0 + feeds don’t display content the first time as mention in another thread
(Even after clear cache/erase date/re-unstall)
@Guybrush There are two problems that I’m looking into.
The first one is the story content when swiping between stories - this one is fixed but not released yet.
The second one is that feed stories sometimes do not load the first time - this one I’m just picking up to investigate.
There have been major changes under the hood, so thanks for bearing with us while we rewrite things
Tags problem cames back too, not possible to add or change a tag, but it’s possible to delete one…
Thanks for the update noneless!
I feel my messages may have be taken as rude, it’s not my intention if that the case, i’m not use to speak/write in english but I try to improve (and it’s fucking slow)
With the last update (13.11.2) tags can be saved in the app \o/
Also they doesn’t appear right away once saved, I have to go back and re-open the story to see the tags but at least it works now!
