Hello! Wondering if it would be possible to add images to the Bluesky ‘Feed’ view. Seems to be text only at the moment.
I tried using the ‘Original’ view but it doesn’t load beyond the site’s background colour.
Cheers!
Cheers!
Got an example feed I can use?
FYI It’s the same thing that:
Thanks for the sample feeds. I’ve added a Bluesky fetcher that does additional fetches to extract all that media from Bluesky. It’s looking good! It should capture future stories and maybe retroactively fill in a few stories. Let me know how that works. You can do an insta-fetch of any of those feeds to see it in action immediately, while the system catches up automatically.
The images work, but it seems it’s not the case for videos on the web (on the app it works fine), they won’t start (I tried refresh the cache, delete cookies and deactivate my adblock with no success :/)
A little up just in case
