Might be better UX if you make the input field for the email for forwarding email newsletters to be read only, since you are not expected to change the email in anyway.
Just should be a readonly prop on the input tag
Thanks! Newsblur is great!
But then how will people be able to post a screenshot of the dialog without changing the input field? I think in terms of user experience it’s OK as is because the field is always correct when opened and I don’t think people expect to edit that field. Also readonly makes selection harder for some browsers.
Makes sense!
