I have a few stories saved on the web UI which I normally use.
When using the iOS app version 10.1 on my iPhone 6 with iOS 12.4.8 I normally have it set to Unread, when I press Focus or Saved stories at the bottom I get the “World” graphic and then “You have no saved stories” (or similar with focus which I don’t use) overlaid the list of folders/sites. You can scroll the page up and down but the label still remains static.
The saved stories are in folders not sure if that makes a difference.
I don’t know if this is something due to the older iOS version or what (I can’t update any higher).
This is what it looks like:
Weird, it isn’t doing it anymore and working as expected, will try and see if I can find what caused it and report back
Thanks for looking into it. If this happens again, please let me know and I’ll open a ticket to get it fixed.
