I can’t see the Story Titles pane. I’ve checked this in both IE and Firefox and I’ve tried setting the preference for top, bottom, and left and it doesn’t show anywhere. Is it possible that I’ve done something to disable it? How can I get it back?
A hunch, you’ve set it to “Full” mode in which the listo of stories is hidden and the selected story fills up that area as well.
Click a site and the check the buttons in the bottom right. Set to “Full”? The left side option? Set it to the middle or right side option.
My hero!
Thanks, looked over the entire screen, except the bottom right.
