I’m forever adding sites to the top level group by mistake and rarely create meaningful folders. This is terrible for my organization and doubly bad for the server. Perhaps it should go: Scan site and then IF a valid feed is found, prompt the user for the folder (and the option to create a new one) afterwards.
I’ve struggled with this, too. That’s actually why I made the “Move Site to Folder” context menu option (since drag-and-drop was a bit too much work).
Haven’t figured out a better way to make this happen, though. I would have to change the flow somehow.
Thanks for the head’s up! I didn’t even know about the context menu option so I do some LONG drags.
