I’ve used NewsBlur premium for a while.
Below is the screenshot from an incognito Chrome tab.
About two in three refreshes got stuck.
Was this resolved?
If not, try using https://www.newsblur.com (note https instead of http) - it is possible that your streams are being corrupted in flight (by your ISP, perhaps) and https would either eliminate that or, if that is indeed the cause and it keeps happening, make Chrome complain about data integrity.
No, it still is.
The problem is the same on HTTPS connection.
I finally find out that the problem is caused by the ad blocker.
I turn off uBlock extension and the web page loads normally.
Finally
