When we will have an Mark as read button? Because it is very annoying to right click on every feed to do that, actually, a lot of time consuming
You can double-click the unread count in the sidebar to mark a feed as read, also there already is one next to the feed title, it’s the one with the square and the checkmark
that button exists only in list mode, not in split mode.
The button also scrolls off the window when scrolling down more than a screen-full of feeds. This is a pain because you scroll to the bottom to read everything, then have to scroll back up to the top to click the button.
Also, if it were to the left of the feed title, instead of the right, it would always be in the same location, no matter how long the title of the feed is. Let’s muscle memory work for you instead of against you.
That said, I’ll try the double-click trick. Thanks.
E.
Shift+A.
