The VTDigger feed returns a SAX Exception. I saw another problem where you had someone check theirs against the W3 feed validator. This one does have some recommendations but is a valid feed. Is this something that should be fixed on your side or their side? And if it’s on their side do you know which of the recommendations need to be followed to get it to work with Newsblur? Thank you.
I updated to that feed and it’s working. Thanks.
