I have bunch of saved news. Mostly on Android.
Once for a time I sit on desktop to read them and then remove.
Problem is that current state of saved news is not reflected/updated on Android app.
There is a long-standing API nuance that makes it so that out-of-client unsaves can take some time to affect state in the Android app, especially in the Saved Stories view. Things should be immediate if you aren’t switching back and forth between web and app within a short time frame (a few hours), or if you unsave from within the app though.
(as a work-around if you really want the story gone, do a refresh in the app and then go to the feed from whence the story originally came and scroll down to it.)
