I have one feed that shows around 200 unread items (which is expected/there should be), but it’s been showing “No stories to read” in the story pane for the past couple of days when I select it. This behavior occurs in both the Android app and newsblur.com. Is there any workaround/way to fix this?
I’m having the same/similar problem the last couple of days.
When I go to “All Site Stories” and my viewing options are set to show “Unread Only” and “Oldest First”, it doesn’t show any feeds. If I change one of these two options then the feeds start to show.
