Only started seeing this in the last few weeks, but have started noticing it with great severity in the last day or so. I click on just about any feed and the number of unread stories in it is higher than the number displayed on the folder or in the header of the story pane.
I’ve noticed many times feeds showing an Unread count of 1 when there were actually 2 unread stories, which means they must not have been showing at all when there was only 1 unread story. My feeds which update only once in two weeks are probably not ever appearing at all.
[Edit: Confirmed, I missed an Order of the Stick!]
I’ve also noticed this quite a bit, and it seems to be getting worse. In the past it was usually that I’d read some items and the counts didn’t update. Now it seems like the count’s don’t accurately reflect the actual number of unread items at all, often showing no unread items when there actually are.
I’ve been having this problem for some time now (reported in a separate thread). Hopefully with more people reporting, it will be easier for Samuel to track down the problem!
This is happening, in tandem with the ghost unread items for me. Regretsy has two unread items, with a count of 1, Atlantic Wire has no unread items, with a count of 2.
This should now be resolved, but that’s because I’m running with new much faster secondary database machines that will no longer suffer from replica lag.
The real solution is coming in a week or so when I try to migrate over to the new DynamoDB, which may or may not be the best solution. But I’m going to try it out and see how it scales.
i am as well still having issues with unread counts, i blamed it on the feeds themselves at the beginning as they tended to update posts quite often… also that seems to be taken care of as you can decide to show edits or not.
OK folks, I made the big push and this bug should now be gone once and for all. If you find an unread count is wrong, it is now some sort of logic bug that I haven’t even seen before. The bug that was causing this issue was directly related to slave lag and now the slave db is no longer being used for counting unreads. Took a while but we now have a system in place that has no performance cost and works without the issues of replica lag.
That is most probably another effect of the huge server load which NewsBlur is currently suffering due to the Google Reader discontinuation announcement. See this tweet from the developer: https://twitter.com/NewsBlur/status/3…
You should give this a day or two until everything goes back to normal.
