I had not noticed it until now, but looks like even though there are unread articles, the feed shows unread count of 0.
Working on the unread counts issue today. Did you share an article from this feed, or alternatively, did you read a story shared from TechCrunch from somebody else?
I did not share anything from this feed (or read anything from somebody elseās shares) today, but I did share back on the 13th. Of course, the problem was only noticed today, could have existed then too.
I never share or read shared stuff. What Iām seeing is that the unread count is always too small, and when I ānā my way through the articles, I go to the next feed before Iāve read everything. Then, a few seconds to minutes later, the correct count for the feed I was formerly reading appears.
Not sure if youāll be able to answer this, but did the feed that had its count updated a few seconds later get new stories?
As for the unread counts issues that Iām working on, they all have to do with shared story feeds and reading the same story that occurs in multiple feeds. A bit edge case for right now. So if there are issues around incorrect unread counts for feeds, tell me more. As you may know, I never experience this, and I think it occurs rarely enough that itās not pervasive, but I want to figure out anything I can about those edge cases.
The biggest issue is that by the time I have a chance to look into a buggy unread count, the moment has passed and the feed probably has a new story which makes the unread count update itself. Counting stories isnāt the problem, itās knowing when to count stories. If you Insta-fetch a feed, it will update your unread count.
Whatās happening here is that a story probably did come in while you were reading the feed, but because you were on the feed, I donāt update your unread count, since Iām not sliding the story in. (Believe it or not, maybe 2 years ago, I did slide in the story as it came in. Thereās vestigial code laying around that in all likelihood still works fine.)
When you finish reading the feed and click to another, after the next refresh (every 60 seconds if youāre a premium, but less often if you are on real-time updates, which is 99.5% of folks), the feed you were reading gets updated with the right count. And opening the site doesnāt correct the count either, but it could potentially fix these problems. Unread count wrong? Just open the site. That would at least ease the pain a little bit, since the count goes away immediately. The problem with that is that it would increase load times from 120ms to 240ms on average for maybe 10% of all feed openings. Wouldnāt be terrible. Iāll see about getting that in today.
Tricky, eh? I know you probably donāt want to hear this question, but how doees Google Reader handle such a thing? They have supported Pubsubhubhub for a while too.
I think I am having the same problem and itās been happening roughly over the past week. I was hoping it would go away, but itās getting worse to the point where the site is practically unusable.
Basically I started to wonder why some feeds which update frequently were not displaying any new articles recently. Then, one of two things happens when I click on the suspicious feed.
I discover that there are new articles which are already marked as read, which I had never been aware of. By that I mean I never saw or skipped them. They were essentially received but ignored by Newsblur.
Iāll click on the feed and see several new unread articles in bold, despite the side panel not listing anything new to read. So I only discovered them when I checked to see if Newsblur was missing something.
This is a pretty serious issue, because if I have to hunt thru all of my various feeds and folders to find articles to read (which may or may not be marked as read or unread, no less) it kind of makes the site useless. Itās frustrating.
Regarding sharing articles, I do this occasionally but I am pretty sure it is happening across the board ā if not every feed it is certainly having problems with feeds I never share articles from. Also, āinsta-fetchā doesnāt make a difference. If Newsblur missed ever marking something as unread and I insta-fetch to see what might be new, nothing happens.
I have a premium account, too, so naturally I expect not to have to insta-fetch too often (although it frequently seems necessary with less popular sites).
These problems seem to be occurring regardless of whether I am actively using the website or away from the computer for a while. For example, thereās a site which updates every morning before I wake up. The past few days, it never reports anything unread. So using the site seems to have nothing to do with the articles being skipped.
I hope this information helps you squash whatever bugs is causing this chaos.
Edit: Oh one other thing, I use www.newsblur.com rather than dev.newsblur.com, but it sounds like the same problem so this seemed like the right place to post.
If youāre premium, sites should be updating every hour at the very minimum, unless the site is real-time, in which case it is roughly 10-20 times less often than normal. So if a popular feed is real-time but wouldāve been fetched every 4 minutes, itās now being fetched every 40-80 minutes.
Can you confirm that most of the feeds giving issues are in real-time? Right-click the feed and itāll tell you if it is in real-time.
As for looking to see what Google Reader does, Iām all for it. I never really used it, but Iām not opposed to seeing how they solve these issues. To be honest, I keep my influence focused on products that are not direct competitors. I think keyboard shortcuts are (mostly) the same as Reader.
So I have a frequently updated site open in Reader and Iāll be watching it to see how the counts are updated. I can easily change that behavior.
Although it seems like the unread counts are just not being counted correctly, which is a big problem. I can wire up a button that forces a recount of all of your feeds. Perhaps I should have that run automatically every hour youāre on the site. But thatās just a big band-aid to the underlying problem. These unread counts *should* be accurate, and in the case of a real-time feed, instantaneously correct.
I am not sure I understand how to tell if the site is real time or not?
However, when they update it seems that either the unread count is ignored (thus I donāt know where to find unread articles), inaccurate (it might say 3 unread but there are 7, for example), or the articles themselves are marked as read before I ever see them (less common, but the most frustrating).
It seems to be happening across the board, and I have 52 sites right nowāsome popular, some not. If itās not every feed, itās most of them.
Also FWIW, Iāve been using Newsblur for several months now (since Google Reader redesigned) and this is certainly a brand new problem for meā¦ so Iād imagine something new/different in the past week must have caused the problem?
The only reason I mentioned GReader is because I had not noticed such an issue there. Once I progress through reading articles in a feed, I would not see mistakenly marked read/unread status. I would see unread count go up for āreal timeā/pubsubhubhub feeds, but very rarely (if at all) would I see an article marked as read, become unread. Or worse, have a feed show 0 unread but in fact have some article actually not read.
Perhaps they have the capacity/scale/inclination to count in real time vs how newsblur does it?
Is there any update on fixing this problem?
I can report that it continues to happen. It seems like itās not as bad, but still quite enough to drive me crazy.
Itās still both problems, too. Some feeds do not register new posts and more often the post count is too low (this is less annoying since at least I know there is something new to read).
I just discovered this happens to me on www, so something will eventually be fixed. But Iām not sure why itās happening. I have an idea and it would explain all the irregularities. The task servers are suffering from some severe clock drift. They are usually behind anywhere from a few seconds to a couple minutes. Itās highly likely that incorrect times are resulting in incorrect counts.
Are your unread counts off by only 1? This issue is specific to normal feeds. Social feeds (blurblogs) do not suffer from this problem, so if those unread counts are off, itās 99% likely that there is a story being shared in multiple blurblogs and you read it in one and the others just havenāt been updated with the correct count. This is a known bug and the fix isnāt so easy.
For me, the feed counts are off by 1 to several.
Iāve been having a few issues with the feeds that seem to be related to one another.
Sometimes I will get new articles in a feed that come in marked as read when I havenāt read them yet.
Sometimes I get articles re-marked as unread after i have read them.
I have a few feeds that donāt seem to tell me when there are new unread articles, but if i check the feed there will be several unread.
I have a couple of feeds where the unread count is just off.
Let me know if you want me to expand on any of those. I havenāt quite picked up a pattern yet, but i think sometimes when the articles come in as read, they eventually wind up getting marked as unread. That doesnāt happen all the time though.
Iām experiencing the same behavior as Ryan, pop race, and the others on āwwwā. At first I thought it was a result of alternately checking my feeds from the iOS app and the site, but I havenāt used the iOS app all day, and Iām still seeing the behavior.
Some of the feeds where I notice this behavior most often are:
daringfireball.net
prollyisnotprobably.com
urbanvelo.org
I donāt know how to tell if those sites are real-time.
Iāve never used sharing on NewsBlur.
Today dev.newsblur has been massively off. So many feed have unread stories, but feed count on the feed and the parent folder is unavailable
Yes, today it has been unavailable as opposed to showing a number which is incorrect.
I just pushed out a fix for what I hope is the issue. It seems that some feeds were timing out during the āmark-feed-as-dirtyā process, which is immediately before the count-unreads process. I separated the two, forcing the subscriptions to at least be marked dirty so each user can force an update (which should happen immediately).
I noticed a rather substantial uptick in incorrect counts as well. Note that NewsBlur is starting to deal with a much larger workload, so some issues that you only see at scale are starting to crop up.
Hereās the commit: https://github.com/samuelclay/NewsBluā¦
Yes, understand. Also, note that I am only referring to dev.newsblur. fwiw.
The backend is the same. Are you saying it works on www but not on dev? Itās nearly guaranteed that itās the same problem. Anyway, I put out a fix and have a background job running through every single subscribed feed to update it to the correct counts, so if you see any incorrect unread counts, shout here.
