Hi,
Since the “feed” issue several days ago I can’t seem to connect to Newsblur.
When I enter my login (louloupix) / password, I get systematically the error below:
NewsBlur experienced an error
The error has been logged and will be fixed soon so you won’t have to see this message again.
Return to NewsBlur
I did reset my password to no avail.
Before encountering the issue, I exported all my feeds in OPML, deleted them from my account and tried to reload them.
Any help would be appreciated.
Thanks
Can somebody please look into this.
Additional information.
When I go to private browsing, I’m able to enter a login/password.
As soon as I enter the password I get the
"NewsBlur experienced an error " error message and can’t enter a login/password anymore until I close and reopen a private session.
If I use another login/password (my wife’s) I have no issue…
Hi there, I just fixed the issue that hit your account. Turns out there was another user with the same username that was left in the system. It may have been you, but I fixed it up and you should be good now.
Sorry about the wait, I’m on vacation until tomorrow.
Thanks a lot Samuel, I’m sorry about your vacations.
I am now able to connect again and believe the other account is me indeed. Looks like it was deleted during the issue and I tried to recreate thinking it would “restore”
Do you have any way to restore my premium account?
I also tried to upload my opml file but I get an error “there was a problem uploading your opml file”. I could manage to enter the feeds manually if you don’t have any way to work around this.
Ok, upgraded your account.
Thanks a lot. I have my newsblur fully working again.
Fwiw I found the issue with the opml. It was due to my “photography” folder that was too big…I had to split it several times to have it work. I guess you may have a limit of imports that can be done at a time but not on the export.
