Hi Samuel,
NewsBlur is awesome, but I have a problem.
1-Every time I want to add a titter feed I have to reauthorize access (Manage > Friends).
Yes, every time.
The thing is that my twitter connection is not recorded.
I’m always asked to reconnect.
It’s really annoying.
What could be the problem?
Could you take a look please?
Twitter feeds seem to be affected by it.
ie: feeds only seem to update after I reauthorize.
2-Any difference between adding twitter.com/username and https:/twitter.com/username?
Thank you
Inkmist
Ok, thanks for letting me know. I just deployed an enormous Twitter rewrite. You should notice that reading Twitter feeds is much, much better all around now. I’m handling quoted tweets, truncated tweets, and auto-expanding t.co URLs. Also, I fixed it so that it will show you the reason for the failure in Statistics/Site Settings if there are any, instead of disconnecting your twitter connection (which was a mistake on my part to do in the first place).
Wow, just in time, right?.
That is great!
Thanks Samuel :-)
Amazing! Now it’s much better!!!
Now I can just use NB for twitter.
