This has been going on for a while now, but the feed here ( http://www.mangahere.co/rss/boku_wa_mari_no_naka.xml ) is showing chapter 30 over and over and over again on Newsblur, I can’t figure out why. If you look at the feed it doesn’t do it there, and it’s not like the date for that entry is being updated or something, it only does it on Newsblur.
I’m not sure what’s going on with the www.mangahere.co
feed, but the www.konzerthaus-dortmund.de feed doesn't validate. Samuel will typically recommend you contact the site to correct the feed.
Yep, if it doesn’t validate then the publisher needs to get it fixed in order for NewsBlur to work.
Thank you, I’ll let them know, and sorry for chiming in as it’s a different problem than the one of the OP.
