About 40% of the time I load a feed, it will switch me from ‘feed view’ to ‘story view’ automatically. This is a problem because a decent number of the sites I follow take me out of Newsblur to the main site if I use story view. I’m using it on Chrome on Windows 7 right now, but I’ve had the issue occur on FF, IE, and Opera, plus Windows 8.
The view is sticky per-feed, so it uses the last view setting you used for that feed.
If you want to temporarily load the story view, hit enter after selecting a story. Same goes for Text view, just hit shift+enter. You can then use the arrow keys (or p/n) to move between stories and return to the preferred view.
