Sort by 'Magic'
I really miss the ‘Sort by Magic’ feature that was in Reader - there are some joke feeds that I don’t necessarily want to read through in order, just in a random way.
How I suggest this could work is sort by random with the 'Focus’ed at the top?
So you effectively want the Unread view, except the focus stories bubbled to the top? You can use the +/- keyboard shortcuts to quickly switch from unread to focus, which might help. As for Google Reader’s magic sorting, I never trusted it and I think it worked off popularity, which doesn’t give it a whole lot of magic.
I have plans to introduce some discoverability into feeds, users, and stories, and this may be a part of it. But I wouldn’t expect that to launch for a while, as I have a few other higher priorities to get to. But it’ll happen eventually.
Yes, sort of, but bundled into one view, in early morning pseudo SQL it would be something like:
SELECT RANDOMID,* FROM MYFEEDS
WHERE NOT READFLAG
ORDER BY FOCUSED,RANDOMID
Random rather than magic, but I never truly liked magic anyway as you’ve said :slight_smile:
