Some feeds show the wrong article body when viewed as a combined folder. The snippet in the article list is fine. Reddit subscriptions are the worst offenders here, though I’ve seen problems with other sites. When I look at the subscription feed, it works fine. This problem occurs on both www and dev, not on android.
Hmm, that’s a new one. Can you post a screenshot?
Note the difference between the snippet and the body text. The body text here is the subreddit description, the snippet is from the article. If I go to the /r/Boston feed instead of the selected Medium Signal folder, the displayed body text is correct.
Ah-ha, you’re in the Text view. The Text view extracts the story content, but it isn’t perfect. In this case, the heuristics can’t figure out the right article body, so it pulls in the page. Switch to the Feed view at bottom.
That was it. Sorry for the confusion. Thanks!
