I often want to copy the link to a feed item and it’d be great if there were a slightly faster/easier way to do it. Right now if you right-click on an item title, you get a popup menu with a number of options (open, save, email, share, intelligence trainer). The “open” option includes a selectable text field with the URL, which can be copied, so that’s already most of the way there, but it would be great if there were a standalone “copy link” option as well (or instead - we can always middle-click or ctrl-click on the title to directly open the link).
I understand that adding options makes the UI more complex but I think this use-case comes up frequently enough to justify the change.
