Small issue with both iPhone and iPad app. When you press on the left side of the “Next” the remaining feed count is incorrect.
Does this only happen when you immediately open a feed while the sync message says “Counting is difficult”? That would be why. If you wait until it says “Syncing Stories” the counts will be accurate.
Samuel-
It goes through the sync routine, then briefly displays “All Done.” All this inter the feeds lists at the bottom left. Number under username is is 141. Number on “Next” button is 224. Latter is incorrect.
Jeff
