Every so often, NewsBlur marks everything in a feed unread. This seems particularly to happen with BoingBoing, and the posts are always marked as “interesting” by the trainer.
If this is an issue with the trainer, is there a way to turn it off completely? It’s a feature that I never use, and it always seems to cause me problems.
This happens most often with Zero Hedge. It’ll go from the normal about to 300-400 unread and you have to work your way back through the past week…
Zero Hedge has a known issue. I have yet to figure out why its happening only to that feed, but this has been an issue for therm for a year now.
As for the trainer it shouldn’t be causing you any issues but id be happy to take a look. Whats your username?
