When I add this site (http://www.fuelfriendsblog.com/), only comments appear in my feed. How can I change this to show the actual (non-comment) entries on the site?
Right-click on the feed and go to Site Settings. You can put in the correct feed address there.
I’ve had this problem with a couple of blogs that I’ve ended up deleting for the time being. I get it 100% of the time with http://blog.jquery.com/feed/ I add it and it just grabs the comments feed. I fix the feed and it either just reverts to http://blog.jquery.com/comments/feed/ as soon as I close the Site Settings or says it failed to fetch the feed. It’s also coming from feedburner ( http://blog.jquery.com/feed/ redirects to http://feeds.feedburner.com/jquery/), so maybe that’s involved in the problem?
Andrew: I was having problems with it reverting just like you mention. After fixing the feed, I closed Newsblur and reopened, and the fix remained. So far so good.
Jeff: I tried that, but when I reloaded, it has the orange !, and when I check Site Settings the feed has a “SAX Exception (553)”, so there must be some mangled XML in the feed or something. I guess that’s a different problem then, leaving aside the initial problem where adding the blog adds the comment feed instead.
