If you have the “automatically switch theme” setting enabled, if you’re reading an article and the brightness gets too low, the app will switch themes but it will jump to the beginning of the article. This can be quite frustrating if you’re reading a long article.
Yes I know about this. It can be fixed but it’ll take a bit of finessing. I’ll add a ticket so one day it’ll happen. https://github.com/samuelclay/NewsBlur/issues/1091
