In the last week or so a lot of pictures in my feeds have not been loading (giving me the broken image holder). It seems a lot of them have been gawker media assets (lifehacker and gizmodo) but I’ve noticed it other places too. Disabled all my extensions to no avail. Anyone having similar problems?
I’m having the same situation with Gizmodo. Some of the pictures show up as a broken place holder.
Check to see if you’re on https. Use newsblur on http.
Or if you have Chrome or Firefox, disable mixed content warnings.
I’m getting the same. Seems to only be gawker media sites.
Made sure http was used, could not find a setting to disable mixed content warnings.
