This morning Newsblur was working great on my phone, as usual, and I was loving it, as usual. Then I updated, and the trouble began. Now the feeds take an amazingly long time to load, and I can only swipe through two or three items before the whole thing crashes. I would absolutely revert back to the earlier version if I could. I appreciate what you were trying to do, but one of my favorite programs just became unusable.
app version: 4.0.0
android version: 4.4.4
device: motorola XT1053 (MSM8960)
memory: normal
speed: 95 in 223
I am having the exact same problem after update. It has become unusable. Crashes as soon as the Newsblur app opens. Is it possible to go back to original version?
app version: 4.0.0
device: LGE Nexus 4 (MAKO)
memory: normal
speed: 0 in 0
Keep the reports coming! There arenāt many problematic devices left, and we went after the common crashes first. Any additional info you can provide about ROM or system utilities in use will be helpful.
Iām also having a lot of performance issues with this new version along with frequent crashing. I like the idea of offline reading but this implementation seems quite problematic.
-Ever since 4.0 came out the app is very slow to load news feeds and unread items. Based on the status banner on the bottom of the screen it seems like instead of displaying the feed āliveā NewsBlur is first caching the feed for offline use and then displaying it. For me this results in a 3-4 second delay before a feedās unread items are displayed, along with another 3-4 second delay when I open a feed item to read.
-Very frequent crashes, usually while swiping between feed items but sometimes also just when opening a single item. I didnāt notice much difference between 4.0 and 4.0.1
As I said, I like the idea of offline caching, but these days itās very infrequent that Iām actually without a network connection of some kind. Offline caching should be something that happens in the background (perhaps with a manual āsync for offlineā button in a menu for when you know youāre about to go offline). Though if I had to guess I would say this caching change was done as much to help us as it was to help with NewsBlur server utilization.
Update (2014/11/24): I ended up having to rollback NewsBlur to 3.7.1 with Titanium, version 4 is basically unusable for me at this point. Really hope this gets fixed.
