Newsblur won't load folders
For the last few days, Newsblur will only open individual feeds, not folders. If I click on a folder, I just get a pulsing blue bar at the top of the center column. I’m using Windows 7 (64 bit) running Waterfox (a Firefox clone)
Sure, what’s your username? I’ll take a look.
I’m ILoveMyGreyhound.
I was able to load every folder, as well as the “Everything” folder. I committed a fix for something that would have had the same problem about 4-5 days ago. It’s possible that it’s been fixed. I’d love to get it fixed if it still doesn’t work. Have you tried in Firefox itself?
