Hello,
i’m using Newsblur on an Ipad Air 2 and I have had a few unwanted theme color switches.
I use the white theme and a few times when opening Newsblur the theme color is switched to grey.
Unfortunately I have been unable to find any pattern leading to this switch.
Regards
Pascal
There is a gesture that switches theme color. It’s a two-finger swipe up or down to switch between the dark and light themes. Sort of like a “light switch”. You can disable it in preferences, but swiping two fingers up or down should move you easily between themes.
Maybe I made accidental swipes, I’ll see if it happens again. Thanks for the info.
