Running Windows 10 (64-bit) and Google Chrome 56.0.2924.87 (64-bit)
After open newsblur.com the feed list is not loading.
Highly likely it’s a browser plugin. Try disabling them and seeing if it loads. Then re-enabling a couple at a time until it breaks again, and then PLEASE let me know which extensions is the culprit.
The culprit plugin is Tampermonkey!
Diasabled and reenabled Tampermonkey, runs without any problem the newsblur.
Thank you!
