Currently in YouTube feeds, we have a nice embedded Video, and the video description under it.
Before the while YouTube API change, the feeds also had info like the channel name (with a link), the duration of the video, views & ratings.
I very much miss the channel link and the duration part and would very much like this back (Ratings and views I don’t care about. That info is dynamic as well, so it’s redundant, since the feeds don’t continually update with this info).
Below I have made a mock up of what I think it should look like. Instead of it saying “From” it could say “User” or “Channel”, although I personally like that the channel link and duration time flush with eachother. Also, I have added a line to separate the info from the video description. (The same line used just above the video).
