Mark one story as read through menu or by double-clicking
I would like it if there was an option to mark a story as read by either double-clicking the story or right-clicking and pressing a menu option “Mark as read”.
The problem I have is that I use “mark as read by pressing ‘u’”. I use vimperator/pentadactyl so it is a bit annoying (plus you have to press the “stories box” to focus it and then press ‘u’). Marking stories as read with a time-out is annoying when I just want to look at different feeds to see if I can read it now or if I should wait. Pressing a feed will then mark the latest story as read and I have to manually mark it as unread.
