I recently wanted to start organizing my feeds but found out that there wasn’t an easy way to move feeds into folders. So, a nice feature addition would probably be being able to drag feeds into folders, or even just an option(in the dropdown menu) for moving the feed.
Drag’n’drop is already implemented. It’s just a little bit fussy.
Yeah, it ain’t perfect, but it works. It’s unfortunate that allowing you to drag-and-drop both sites and folders is why it’s so fussy. I’ve spent mega-hours trying to get it to work perfectly, but it’s not happening anytime soon. But it does work. You can even drag sites and other folders into empty folders. There’s a small opening for them. Just make sure the folder isn’t collapsed.
