Make the save story/tag box appear top right of article in text view mode, it’s a bit annoying to have to scroll to the bottom to save/add tags
You can move the story actions to the right of the story in Preferences. You’ll need to make the text view wide enough, though. You can also right-click the story title.
Great thankyou, sorry I missed the option in preferences… Thanks for the great work
