For the past week or so I have noticed that my Huffington Post local feed is not launching the correct url when I use the “o” key. If I try to open the link using the keyboard shortcut it just opens an empty window. If I click in the link it goes to www.newsblur.com. This is the only feed where I am seeing the problem.
Here is the feed taken from the site settings dialog:
http://www.huffingtonpost.com/feeds/v…
If I view the above link directly the links all work properly.
Hopefully this is an easy fix. There are 4 other subscribers for this feed.
Tested this using Firefox 8.0 and latest version of Chrome.
Thank you.
