Beta app has been working without issue. Used it this morning as expected. Just tried it now and it is saying the beta has expired. There are no instructions, there was no notice. Is there a way to continue the beta? If not, how do I get newsblur to work?
You can uninstall the beta, then re-install NewsBlur from the App store. That would at least get you back up and running quickly. Samuel would have to speak to the status of beta builds.
You should be able to just install NewsBlur from the App Store. Unfortunately TestFlight does not handle expiration very well.
From Twitter:
Thanks. Looks like installing the regular app over the beta got things working again and kept all settings.
