The website doesn’t display any of them, but the iPhone app does.
I had this problem and it was because I was using AdBlock. I whitelisted it for newsblur.com and it works (though of course it also shows ads in the feeds that have them).
Hmm, I’m using Adblock in safari, too. Tried disabling the extension on newsblur.com as you suggested but it didn’t work out.
Looks like there is some problem with AdBlock getting stuck or something - I tried to whitelist the page, but it didn’t work. After I disabled most extentsion, reloaded, enabled extensions again, AdBlock now properly whitelists newsblur.com and uncrate feed is shown correctly.
