Many times when I try to use the “Everything” combined feed I get an error. My username is “Dude”
Thanks.
Thanks.
There actually is an error that comes with it, but it’s hidden. If you know how to inspect the request, you could see what’s actually happening. It’s more likely that it’s a limitation for how many feeds can be fetched at once. The problem can be traced to MongoDB’s inline MapReduce limitation. It’s something that i’d like to fix, but if there are thousands of stories, it has to sort every single one of them to figure out which ones to show in order.
Anyway, for now, do you have any folders that you can read instead? Are there any high volume feeds that could be sorted away? The issue is just too much data to handle at once.
