I am having issues with my newsblur channel on IFTTT.
When i go to edit, or create a recipe with the trigger New Saved Story, the tags drop down shows Options Unavailable, please try again later. https://db.tt/mUyQW2NT
I have edited the channel and reauthorized it, which didn’t change the message.
I also have a message in to them about this.
–Ryan
I’ve sene this myself as well. Looks like the issue is on IFTTT’s side.
okie, thanks!
I’m having the same problem, but it’s become more critical since Instapaper’s channel changed, destroying my “if (save on news blur) then (read later on instapaper)” recipe. Any chance of helping ifttt resolving this? It’s hard for us users to prove to ifttt that it’s their problem not newsblur’s.
Thanks!
I’m having trouble, too. I’m trying to do a “if saved to Newsblur [with a specific tag] then post to Instapaper” recipe, but when I get to the drop-down to select a Newsblur tag there are no options. Instead it says “Options unavailable, please try again later!”
http://megmo.me/1meOxbQ
My tags exist in Newsblur, so I’m guessing this is an issue on IFTTT’s end.
It is on their end, unfortunately. They use the same API that newsblur.com uses, so if newsblur.com is working then IFTTT should be getting the right data.
OK, I also filed a bug report email with IFTTT and we’ll see what happens.
Your fix (mentioned at https://getsatisfaction.com/newsblur/… ) worked for me.
